Fibreglass panels wanted for Dart
WAR440
New Member
Sydney
Hi im chasing a bolt on fibreglass trunk and rear bumper bar for 69 Dart. Or somewhere quality to buy them. Also after 8 3/4 or dana for a body. Thanks
Unlimited I believe have them as well as us body source for the fiberglass. Think his name on here is glasstek he does fiberglass as well
You can order a new Dana 60 from strange engineering for around 2 grand or so, that's what i would do for a rear end.
at least 2k without shipping to sydney? Look up my thread called "budget dana" your wallet will be much happier.
A lot of people don't have the ability to build it themselves, that's why i posted what i posted.
It would be new, and a bolt in.
....and, the Super 60 has side adjusters which takes out the pita case spreader involved in using a stock dana 60 for shim adjustments. We've called Cass on a number of brake and rear gear needs:
Strange S-60 for Mopar, Ford, Chevy/GM
...and brackets for those glass bumpers? Jeff is a member here and has some nice stuff!
Lingenfelters brackets - Home
I currently have a glass front bumper on my Duster from Unlimited and will be getting a rear one soon. Both attached with the above brackets :)
well I sure appreciate credit for rebuilding a Dana 60 myself, but I kind of directed The build in a budget sort of way. again that's why I recommended reading the thread that I had on a budget Dana 60 build. I'm sure shipping to what I believe is Sydney Australia? it's going to be a killer. I checked into the Dana 60 from strange engineering Myself and found that the two grand was a starting point now if you wanted lug nuts excetera excetera that was considerably extra. When all is said and done and more it was done than said I was into my Dana 60 about 12 to $1,300 the same amount I put into a Mopar 8 and three-quarter 489 case with new gears blah blah blah and blew up at the track after 30 passes. My rule of thumb for cyber spending others money as cheap as possible. I could always go tell him to drive to the store and buy one brand new. I'm sure if the guy can take his rear end out and put a new one in and change his brake plate over with his breaks which of course you would have to do with the one from strange engineering he can go one little step further and slide in the axles witch is as simple as pie with green bearings.
