filler neck gromet
two_70darts
HERCULES CALIF.
1970 dodge dart in trunk filler neck through floor to tank does any body no if any one sells rubber seal for this location i thought i saw a artical of cousre cant ind it that said this gromet gascet was the same on some other a bodie any please mine looks nasssty this is gasket where tube psses through the body its about 5inch by 11 any help would be greatly apr... thankz alot:happy10:
I have one from the 70 dart I am stripping,,,if I remember right its in good shape,,,,I'll check it tommorrow when I get to my shop
Layson's lists it as part # DD-A0710 for $32.
While we're on the subject, I havent found the gasket for the top end of the fill tube at the quarter panel, also for a '70 Dart. Or the one on the trunk floor under the base of that fuel evap control pipe whatchamacallit that at least the CA cars have...
I guess I can pretty easily cut these out myself if I can't find them.
thanks alot everyone aprt. the help been a while since i looked for it it seems as youall are saying its avl now sweet thankz again see ya on the road:happy10:
