So I'm finalizing my 440 build. Just wanted to see what some thoughts were.
73 440 block. .030 over, Zero Deck
1968 Forged 440 crank, re-balanced by machine shop
Aluminum Main Caps with Main girdle(still shopping for best one here)
Eagle 6.760 H Beam Rods
Ross Forged Flat tops with Valve Relief. Compression Height of 2.065
Comp Cams XE 284 cam, specs 284/296, Lift .507/.510
Schumacher Tri-Ys
Edelbrock Torker II intake
Holley 950 on topChanging this to a 750 based on recommendations so far
Edelbrock Performer RPM heads. Can't decide between the 84 or 88 CC head. Heads will be upgraded to Comp valve springs.
Goal here is a 450 fwhp. going in a 74 dart swinger 2 dr hd top with a 833 4spd, 8.75 and 3.91 gears.
:burnout:
Schumacher Tri-Ys
:burnout:
