finally got around to installing the new springs today..
abodyjoe
Berlin,N.J. 08009
got a set of eaton springs for jamies dart back in july.. ordered them from pete at http://www.bergmanautocraft.com/
the car had a set of +1" espo 5 leaf springs on it.. i didn't like how high they sat (24" from the ground to the wheel well) so i put a set of 1.5" lowering blocks on ot to get the car to sit the right way..:) it put the back at 22.5" from the ground tot he wheel well... i liked that look but thought the 5 leaf springs were too soft ,especially after the trip to carlisle all loaded up.
so i got ahold of pete and he sold me these eaton springs.. stock height.. that wheel well is now 23" from the ground. i'll put some miles on it and see if it settles out any, if not i'll probably put a 1/2 inch block in it to put it where i really want though..
one note: if you are going from 6cyl. to these things you'll have to drill out the front mount hole to 5/8". the v-8 uses a bigger spring eye bolt then the 6cyl. not a big deal but just something you should know..
espo +1"
with the +1" springs it sat at 24" to the wheelwell...
ESPO +1" SPRING WITH 1.5" LOWERING BLOCK
with the 1.5" lowering blocks it sat at 22.5" to the same spot
now with stock height eaton sprngs..
23" to that same spot..
...don't know why but sitting real high has a big following.Like you i prefer stock or a tad lower for the benefits alone.
Show us a full profile of the new springs ride height.
I will when I can. Dark now and working the next two days till dark so hopefully Friday.
So 23" from the ground to the top of the wheel arch with 225/70/14's?
That's a 26.5" tire according to the specs, for anyone that wants to figure out where their car would sit with a different height tire...
ok here is the different stages along the way..lol
espo +1" springs
about 24 inches from the grount to the wheel well..
espo +1" springs with a 1.5" lowering block in it..
about 22.5 inches from the ground to the wheelwell..
eaton stock height springs.
about 23" from the ground tot he wheelwell.. tires are bout 1" shorter in dia at 25.6" then the ones with rally wheels 26.4" in dia...
i think a half inch block will put it where i want it (especially after its loaded for a trip..:) ).. if i ordered the springs again i'd probably buy the 1" under stock height.
Looks good both ways but I like the dog dishes over the rallys. Dads FB sits way up in the arse end like a cat in heat lol. I think it has Xhd but not sure...
oh i hate the over done ugly *** rally wheels. they weren't even an option. just something i threw on when we went to big bolt until the body color wheels and tires were ready.. i'm more concerned with the stance..
