Finally got the new clutch fan in
Brooks James
VET, CPT, Huey Medevac Pilot
Fruitland Park Fl
It is the minimum 3/4 inch from the rad, just as the manufacturer stated.
Hi vol, big rad, clutch fan, if that doesn't get it I have a sheet metal buddy who will do a shroud for me. Im not sure what pressure cap to put on it. I was thinking 16 lbs.
Put the Holley back on , the TQ won't fit with the nitrous plate and the filter
Run the lowest pressure cap you can without it puking coolant out of the overflow. Less pressure means less stress on the cooling system. If you have enough radiator you won't need a high pressure cap. I run a 13 pound cap on Vixen and Gladys both and they do fine.
