mopowers
It doesn't matter. As long as you know what stroke you're on when you install the distributor.
yes you can do it in the same position you're at now, just use a straight edge to line up dots. its just easier to align them in #6 position, especially if you don't plan on degreeing the cam, which i'm sure you'll hear lots about if you're not!I'm confused. The shop manual goes on about how important it is to have nb 1 cylinder at tdc on the compression stroke before removing the cam and be sure not to move the crank after this. Are you saying I should turn it over to tdc on nr 6 cylinder, align dot to dot and then turn it over to nr 1 again???
Just out of curiosity, why cant I just install the cam just the same position as the one I took out?
Thanks. First things first I guessyes you can do it in the same position you're at now, just use a straight edge to line up dots. its just easier to align them in #6 position, especially if you don't plan on degreeing the cam, which i'm sure you'll hear lots about if you're not!
It will be easy once You have the dots lined up either way,...just remember this...... put a lifter in the block for intake #1(2nd lifter bore back on the left side bank).Thanks. First things first I guess
Thanks. I was thinking along those lines.If you are going to let the engine set for awhile, I would leave the intake loose, I use those small acid brush to recoat the cam lobes with paste, and put a small dap of paste on the bottom of the lifter...coat the body or the lifter gallery with regular motor oil...the lifter needs to be free to move to break in the cam...then bolt on intake manifold...
Plus prior to putting intake on....prime the engine with the oil pump...and slowly move the engine by hand ....
Thanks!It will be easy once You have the dots lined up either way,...just remember this...... put a lifter in the block for intake #1(2nd lifter bore back on the left side bank).
Roll the engine clockwise & watch the lifter, when it is on the way down, the next time the piston is up is TDC compression....that's it.
Thanks! I have never ported before. 318willruns videos on YouTube gave me the courage to try it. It is taking me ages. I work them some every time I'm in the garage. I dont think I dare to take more material now. So I will start polish everything with sandpaper rolls. Would you consider the surface on the picture good enough, they say "leave the intake ports" a little rougher?You're bowl work looks really good, just don't get greedy and find water. J.Rob
Thanks. It was your videos and responses that gave me the courage to do this.I would polish the exhaust ports, not the intakes. Buffers for dremels will make the exhaust side looked like polished aluminum
Thanks! Now I have a few options to look atWe used these engine tech valves on my dad's 360. They were only a few bucks apiece and worked out very well.
More Information for ENGINETECH V1721
As in cutting the seats? Only if necessary, I'm doing this on a budget. Yes, getting new exhaust valves.Are you not machining the heads?
The guides with excessive slop will be machined, so will the seats, but only if the machinist deems it necessary.They aren't gonna go very far, the guides are worn, but what the heck, at least you get an idea if the port work ...worked, by how it feels in comparison.
