B3422w5
Nice job!
Just wanted to share
with the help of protrans
Along with a ton of work trial and error
And countless passes …
This 904 is doing everything I’ve asked
Reliable,, I let go of the button at 5000rpm
And have had no issues roughly 3000lbs
Reaction time is on point …
.00’s to low .020’s is cake …
Just wanted to share there was a time I was thinking this thing just couldn’t react
Ok so I am confused. I thought you attributed your progress to the ladder bar suspension versus the Caltracs.Just wanted to share
Ladder bars where a step in the right direction car got consistent and reliable .Ok so I am confused. I thought you attributed your progress to the ladder bar suspension versus the Caltracs.
What changes have come from the trans.
now if I could only get it to drive the stripe for me . Haha
The Caltrac’s where just to hit or miss..
Ladder bars let me focus .. on the rest of the car
Continued to grind on it ,
Reaction time got better
Protrans had some valve body transbrake
Release ideas they did them
Seat time
Seat time
Car is better
Work work work
Timeslips have proven
That the progress isn’t just a fluke ..
Hmmm, I wonder if your problem was transbrake release all along,Ladder bars where a step in the right direction car got consistent and reliable .
Seat time
Seat time
Car is better
Work work work
Calvert has on their website the first car to run 6,s on leaf springs.
6.98 et, so Caltracs can work. But if your transbrake had a problem, no suspension can work properly. What made you contact protrans.
How did you conclude that the brake needed to be looked at?
I have followed this thread. Just saying that you had implied that your problem was all suspension. Then you mentioned trans brake.I know people go fast on leaf springs
I hear that statement all the time ..
And they can be made to work. Most of the time those guys race 3/4 times a year
On fly paper prepped track
My car is slow and countless passes a year
Some tracks are awesome and some not so much .
I’m not gonna go into the instant center deal with a mopar leaf spring ..
But it can be made to work , for me “working” wasn’t good enough .
And the ladder bars are miles ahead of a mopar leaf spring deal ..
I do believe with less of a first gear the springs would be better ..(powerglide)
if you decide to go with a leaf spring deal along with a .4ths protree let me know .
Never said I had a problem with the brake
What I’m saying is always Looking to better my program IE reaction time etc….. and protrans found a way to make the release faster ..
You need to look at calverts drawings of how the bars work.Ok,
I had to get the car to leave the way I wanted it to , and to do it consistently.
I fought and fought the Caltrac’s but could not get them to do what I wanted ,
Caltrac’s tech support was not much help
Other then suggesting shock adjustment.
I decided to move away from the leaf springs. After exhausting myself with them
And went to ladder bars
Car went to doing exactly what I wanted at the starting line ( snatching the tire out of the beams)..
So my next move was to start working on reaction time and sure enough got it where I
Want/need to be competitive in our local index class ..
I would never switch back unless I was footbraking
Putting on a set of Caltrac’s does not change the instant center ,
The instant center is where the front segment of the leaf spring mounts to the Chassis ,
Which in a mopar is short vs brand x
Which in turn will hit the tire very hard
And will release all pressure very quickly down track ..
You mean moved it forward? If the attachment point is still in the same place then that changes nothing. If you moved the attachment point forward like ladder bars do, then that changes the instant center. A longer leaf spring front segment mounted in the same location would not change instant center very much unless you move the axle back.O ok . So if I lengthened the front spring segment that doesn’t change the instant center ..
As I said in my previous post, the main thing is you got the car to do what you want. Always more than one way to skin a cat as they say, and you are out there having fun and clearly turning on some win lights. You are way ahead of me as my car is not quite ready yet. I was only following your thread because I recently decide to change over to Caltracs, but I did a lot of research before making that decision. You are not the first person who could not get the Caltracs to work. Apparently it is very easy to get lost in the adjustments. I am trying to learn from you as well. Your out there racing, that's why I asked about your trans. I was not trying to pick on you. Sorry if that's how I came across. Good luck to you and beat the chebbies lol.Ok my friend I get it you are very knowledgeable and are a ton of help on this forum, and I appreciate your “help” and with all do respect I hope you have a some fun racing and turn on some win lights ..
If you where local to me I would love to
Get you in the other lane , and I’m in the Houston Texas area just encase your are
Even would be better if you join the local circuit, would love to see how you would stack up .
I Index race 6.50/7.0 which is no secret
I’m simple sharing my experience with leaf springs , ladder bars , protree racing and the like. Hopefully another enthusiast can use my experience to help them get where they need to be faster ..
Looking back I could have done ghings different but I’m ok with my journey
Been a blast .
