Have any of you guys ever tried this.
Element E50 Fire Extinguisher Review - Off-Road Ready & Trail-Tested
Interesting...From the video, it looks like you would have to get pretty close to the fire to put it out. I'm not a fire fighter but used to be involved in nuclear fire brigade training and some of these fires can get pretty darn hot. I'm curious if you could stand the heat long enough to put a fire out? Oh, another video... well it depends on the size of the fire I guess. It looks pretty cool.Have any of you guys ever tried this.
I have t3sted that brand. IMO you need the bigger of the two models to have a chance at being affective. Halon variants are okay however the deprive you from oxygen and one the cloud is dissipated your fire will be able to reignite.
That said I opted for a clean agent foam extinguisher. It won't eat the paint, foams and is a good size:
https://www.summitracing.com/parts/LFL-201-100-003
Foam does not, only in the space it occupies. Dry chemical interacts with the fire, but it is breathable and an irritant and partially toxic, but less so than the fire itself.ANY extinguisher removes (displaces) air / oxygen. I would not want to be "the experiment" for that until it's undergone LOTS of testing.
It takes approx 4 minutes for one to expire from lack of O2, fire can cause fatal injuries in mere seconds, and then takes hours to put your lights out for good.I know most of you guys have heard this but when I wrecked at Norwalk and slid a 1/2 mile on my roof I had my hand on my Halon system. I couldn’t get out of the car so if I caught fire I was pulling the Halon. I’d rather suffocate than burn to death. Luckily neither happened.
The choice seems rather obvious to me.
I like Halon for its easy clean up and lack visual obstruction. Special K is best around fire agent for non EV cars but it pretty much ruins whatever you are trying to save, besides yourself.
I try to have access to both, so I can proportion my response.
"Class K fire extinguishers use special extinguishing agents that separate and absorb the heat elements of the fire – the fuel, oxygen, and heat necessary to start a fire. The wet mist contains potassium acetate, potassium carbonate, or potassium citrate mixed with the cooking grease to create a blanket that will cool the flammable liquid and block oxygen, extinguishing the flames and preventing reignition"
I had the impression Halon is a rather rare left over fire agent no longer used mainly because of its severe ozone depletion characteristics, and getting them refilled is rather difficult and expensive, to the point they are only worth discussing if already owned and then become a one and done fire solution.
Halon is most effective in confined spaces, as in the outdoors or in any wind it is much less effective in displacing O2. It is not overly toxic beyond its O2 displacement properties.
Pick your Poison.
