Firm feel power steering
jfaabody
Active Member
I'm looking to replace my power steering box in the duster. I was thinking firm feel, but which one? Stage 1,2, or 3? Mostly used to drive around town, light to light! Right now the car seems to wonder a bit and the steering is a bit unresponsive. Any suggestions? Anyone use firm feel?
I think there is a 4 now. Most guys that went with the 1 or 2 usually say they wish they went 3. That said I like the old overpower steering.
I have a 1 in my Valiant and it's perfect. About the same feel as a new, modern car.
I like the stage 2 or 3. Somethign to consider - if you have no other suspension or wheel improvements, and run the "normal" old type musclcare tires (even radials) the car may feel like it's wandering when compared to a modern car - assuming you're used to a modern ride.
I have had both. Go with the Stage III. You will not regret it. They have an option where they upgrade the seal on the input shaft which is a good idea.
