951mopar
I am attempting my first 8 3/4 rearend assembly and I have a few questions. First, let me list what I am assembling. It is a 741 with richmond 3.55, Auburn suregrip, A-body housing, axles from Dr. Diff with green bearings. The center section is already assembled with all new gears and suregrip.
Should I used a little silicone or AVT on the center section gasket or go without?
What kind of grease for the bearings?
I have the additive for the rearend fluid, but what brand of fluid should be used. Any input or advice other than was mentioned above would be appreciated. I do not want put it together and installed and have to remove it. Just trying to avoid mistakes.:burnout:Thanks
