LOL! On a good day but true enough that’s for sure. You only need the compression to keep the cam and engine in the efficient way of the dynamic workings. Since the bigger the cam is the more pressure it bleeds off this the need to raise the static ratio.The difference between 9:1 and 9.5:1 is 5-10 hp not enough to worry over.
This right here is the answer all of us 318 guys have been asking !! Lol thanks MO!Just make sure the dynamic isnt lower than 8.1 and not higher than 8.4.
Static compression can be 10. Or 9.5, just get a good dynamic=cranking psi.
So I’m going to build my 318 soon and here are the parts I have for it, stock 71 318 block rods and crank.
It is not in the peak HP which is all that number means; I sure wish folks would get away from that stupid HP vs CR Wallace calculator (which is not accurate anyway). It is totally misleading as to the outcome of SCR/DCR changes.The difference between 9:1 and 9.5:1 is 5-10 hp not enough to worry over.
OK LOL will try to do that. Tnx for the invite!You come down here on a hot humid day and say that. You'll change your mind real quick. I don't care what those 30 plus year old studies showed. lol
wow, this is being made WAY more difficult than it needs to be, than it has to be, than it should be. It takes pages to discuss DCR/static, what's correct, altitude, longitude, full moon, on a Septober night! LOL.
I get what your saying and understand. My point is, the "experts" will conflict/contradict each other on something that really isn't a deal breaker at all for the OP's build. Tell me, do you feel "more wiser" when somebody says "static of no more than 8.1" and the next says "naw, I run 8.8 all the time and no issues". You can read this and you know which one is right? Look, the OP wants to throw some freshened 360 heads on a 318 with a mild cam, 4bbl, and some street pistons. Put it together, and if she's a little fussy on todays gas (i'm betting not), pull a few degrees of timing out. If she is doing great, pull the timing up till it's happy! this isn't that difficult. When some of the "experts" get done, it don't seem safe to build an engine. You think Chrysler cc'd every head, measured every piston in the hole and every deck height? I'm not saying these things aren't good, i'm saying don't spend 1189 dollars and 27 cents to go from a 7.9 to ones "opinion" of a desired 8.2... LOL.I'm still learning so I appreciate all these drown out threads. I want to understand the whole process. I know alot of you guys have been there done that a million times it it's annoying to answer the same questions over and over but for the guys like me who havent build 100 engines and don't know we are still learning and need answers to the little question. There are 2 types of car ppl.
1) the ones that drop there engines and cars off at a shop and let someone else do the work
2)the diy that does all that he can himself
I fall into 2 I'm trying to learn all I can I know alot of the learning process is trial and error. But with all the wealth of knowledge here alot of error can be avoided.
Oh absolutely I get what you are saying. I get confused alot on here by the different opinions. One guy says this another says that. And honestly I dont know any difference between the two. HahaI get what your saying and understand. My point is, the "experts" will conflict/contradict each other on something that really isn't a deal breaker at all for the OP's build. Tell me, do you feel "more wiser" when somebody says "static of no more than 8.1" and the next says "naw, I run 8.8 all the time and no issues". You can read this and you know which one is right? Look, the OP wants to throw some freshened 360 heads on a 318 with a mild cam, 4bbl, and some street pistons. Put it together, and if she's a little fussy on todays gas (i'm betting not), pull a few degrees of timing out. If she is doing great, pull the timing up till it's happy! this isn't that difficult. When some of the "experts" get done, it don't seem safe to build an engine. You think Chrysler cc'd every head, measured every piston in the hole and every deck height? I'm not saying these things aren't good, i'm saying don't spend 1189 dollars and 27 cents to go from a 7.9 to ones "opinion" of a desired 8.2... LOL.
The operating difference for DCR shows up in the low RPM torque. Anyone with hot rod sense will indeed feel a difference of .25 point of DCR in everyday driving, in terms of throttle response. 0.5 point will be noticeably quicker taking off. A full point of DCR makes the engine a very different animal.
So, for a street engine, CR IS quite worth worrying over, as well as forsome racing disciplines. Drag racers just work around it with high stall torque converters, etc., but that is not what works well for a road race car or rally car, where the wider torque band, extended down to the lower RPM's, is very much needed.... or for some street usage if you don't want to rev to 2500+ RPM just to move away from a stop sign. (Though some people may like that LOL)
I understand. Be careful is the number 1 rule. "I" would not go much past 7.5 DCR.
Where does one learn such rule?
Nothing less than, perhaps.
@ 8.88889 seems to be the max near sea level with some quench. He has none "to my knowledge" so anything under 8.1 would be absolutely safe, basing that on my repeated experience.
My .030 kb hyoer 340 ran 160psi @9.5 compression 69cc heads pistons and around .020 out of the hole. Valve closed iirr 58*
In other words 130-140 PSI is kind of like stock territory... we need to be 150 or better if we're really trying to build any kind of performance or even stock performance motor.
There are engines out there that dont fit the above, but we'll stick to this 340 for now.
Why 150 or better? You can take a stone stock engine and add bolt ons and add a good bit, you know that. Good intake, carburetor, headers and distributor you can adjust mechanical advance on. Come on man, he's not building something to go racing here. He may not have the budget to do what you're talkin about. I haven't read every post, so maybe he does, but I try to approach it like someone is on a budget until they say otherwise.
I completely do agree with you though that if his budget allows he should get cylinder pressure up there. Does he have to? Not in my opinion.
And where did I learn that rule? Trial and error doin stupid **** as a kid.
If it were me....That's all each of us can say "depending on the perspective"...either of us are right.
Short stroke engines can really use the extra snap. Stock is around 145psi. Not terrible, but not what I'd call high performance.
Happy Thanksgiving btw
I'd be surprised if the poor guy visits the site again. Happy Thanksgiving to all my MOPAR brothers and sisters!!Right back at ya! Hope you feasted good!
Yeah bottom end balance is something I plan to have done on this engine, and all this is definitely a lot but I read it all and I’m just tryna learn what I can.For the OP, if he is still here, just be advised that using the KB167 pistons will typically require a re-balance of the crank to match the lighter piston weights. There looks to be a trick to avoid this with your earlier crank and rods; let me know if interested.
