The M is in the way of where the arm rest was.
If you look close you can see holes where some dummy put the M on upside down at first! If we use the arm rest we will have to make the M smaller and relocate it. We where thinking of maybe no arm rests in the back.
The padding is 1/2" thick, where thinking 1/4 might be better. We had to cut the pad out in the area where the window crank is to keep it from rubbing.
Larry made the M out of MDF on his C&C machine and we painted it gray, but where thinking body color might look better. Or maybe polished aluminum.
