Fitech Command center 2.0 return line (in 1970 Dodge Dart)
tx70dart
Member
TX
I have a 1970 dodge dart Would it be possible to run the return line from my filler neck to my command unit using the existing nipple but replacing the hose...
Not really because:
1. There is a lot of gas flowing thru there, and I can almost guarantee you the gas cap will leak.
2. You will lose your vent.
3. The gas will become aerated which isn't a good thing (this is why the return should be submerged in the gas).
I thought the whole point of the "Command Center" was that it didn't need a return line to the tank?
