HERE IS WHY There are two ignition feeds out into the engine bay IGN1 "run" is ONLY HOT during "run." It goes dead during "start." To supply ignition power during "start" the (usually) brown bypass circuit, IGN2 comes from the key, out into the engine bay, and ties to the coil+ side of the ballast. This feeds "hot" battery voltage to the coil for a hot spark during starting.
All this essentially originates at the ignition switch. It only has so many outputs. They are:
1..."igntion run" usually dark blue, IGN1. Hot ONLY in "run."
2...."bypass" normally brown. IGN2, Hot only in "start"
3...."Start" normally yellow. Goes to the starter relay. Hot only in "start"
4...."accessory." Hot in either run or accessory. Feeds switched accessories through the fuse panel
