Hello. I've got plastic fenders on my barracuda. Not sure if the headlight bezels fits correctly? Can somebody post a picture so that I can see if it fits correct. Wasn't able to flip the darn picture.
Thanks
Daniel
When you say so yes there is a tab. It looks like it´s the correct bucket. Can you take a picture from the other side so I can se how the tab should sit?
I'll bet the bucket isn't aligned perfectly or is slightly twisted or bent.. misaligned one on a fiberglass install on a Scamp a few years ago - - it all fit because it's just a trim ring on the headlight, but the headlight itself was angled to the left a few degrees.. that was fun to fix!
On mine, both L&R rings, appear to have been removed at some point.
However, I do have a spare that has been on another vehicle that has the tab intact. There is rust on the tab from the screw indicates the mount hole was very close. See picture.
Given the screw hole location and tab right next to it, I can't see a full tab seating properly on mine either.
If I were a betting person, I'd almost bet this tab should be trimmed to fit to grille depth so it acts as a stop to not smash the egg crate as the ring is tightened down.
IDK, anyone know of a '69 headlight bucket bracket design change? What are we missing? :scratch:
