Fitting TTi headers on a 273
We never came up with a good reason why there was so much tolerance allowed from head to head. All I can say is we were not the first to see this. For whatever reason Chrysler apparently didn't see the need to hold a close relationship from the mounting bolt pattern to the port openings. You'll find this to some degree on the intake side as well.
If you have the capacity to machine the flanges flat IMO you'll be far ahead of the game in terms of sealing. And if they are actually straight and flat you can cut away the excess flange between center ports and the ends. I wouldn't do that with TTIs normally because the centers help pull the ends flat, or flatter anyway.
PS. If you do need to recoat - look into Zircotech on your side of the pond for several nice zirconiumdioxide options.
I’ve got milling machines - so we will be able to mill them flat if necessary.
Good idea about the support from middle to end. Removing it will help pull the header down.
I haven't seen the current version but in my experience sadly there is no room to do this.
I don't think its been changed that much if at all. But I was an early guinea pig.
You can see how close it come to the rail here.
There still needs to be room for the head pipe to make the turn which also has to clear the t-bar.
This gives some idea of the room to t-bar.
Again the design may have been slightly changed since then, and my car just may be 'special'.
Mattax, tolerances stack up, could just be a slight shift on the mounts to give the required clearance. Also doesnt even need to be 1/8, I bet 16g would work too, just enough to give it a backing. 16g over a 2-3mm gap will provide plenty of support for a flange. UK's headers collectors are way up there, I think he has much more clearance/leaway than we usually see with full or 3/4 length headers. maybe just a kiss on the outside of the flange with a grinder. plenty of meat there.
That sounds good. The trick will be fixturing it. Others do it. They may use a jig on a belt sander. Headers by Ed used to do it. Calvin Elston and all of the custom builders do too. This evening I can search on Speedtalk forum - I know it came up in discussions.
I kindof hesitated to post these here, but this what I found.
I did the best I could using a glass plate and sand cloth, but the overall arch was more than I could address. I wasn't terribly concerned using the fat gaskets and such a thick flange.
What about slotting the bolt holes to the low side and pulling the header UP slightly when installing. That distance to cover for a decent sealing edge may be a reach on this one. Is that a possibility instead of welding on them or making a plate.
Jig that in a mill and be done in quick fashion. Or hillbilly it with a dremel or drill...
There have been issues before with tti and ported heads as well where the sealing surfaces are not close to each other. Only option was to tig them up and mill the surface.
I've been using a big flat file, since the 60's. (and sometimes a welder and/or grinder/belt sander)) to true and change the angle the headers leave the engine, by filing the flanges.
It.s no big deal, it's a last resort for gaining clearances, but used to be absolutely nec. to get the old headers to seal.
It takes very little material off a flange to get 3/16 on a lower tube, or the collector.
Thanks for putting the pictures on.
I’ve got the idea now.
They need to be perfectly flat to seal.
I’ll have a go at them tomorrow.
Thanks for your help
Hi there.
Good idea - I will have a look tomorrow- maybe possible.
I have a milling machine that I could slot the holes longer.
Thanks for your message.
I've been using a big flat file, (and sometimes a welder and/or grinder) to true and change the angle the headers leave the engine by filing the flanges since the 60's.
This is my first Mopar so I’m learning all the time.
It looks like people have had this problem before.
It’s a good job I can come on here and ask questions.
I’ll have a go tomorrow- welding filing -milling etc.
Cheers
Hello
Just a quick update.
I’ve welded my ports up on my new headers.
They are now machined on the face - so they are flat.
I’ve bolted each header to a piece of steel flat and tried a 0.002” feeler gauge under.
I couldn’t get the gauge under so they should all be good now.
Thank you all for your help
Mark
Nope, your car is fine Mat. Those shorty headers have never fit. Especially early A's. They were originally designed for trucks weren't they?
It's been a while but I think TTI always intended these for cars. They do not fit '66 and earlier. TTI had made them to fit them in a late 60s or early 70s A-body so I wasn't expecting complications. After tying Rob's lift for 3 days I made the decision to cut both our losses. There were at least 3 more modifications it looked to be needed to make them work. My car may just be on the tight side of certain production tolerances. The 340 headpipes made by Accurate hung low, and the distance from distributor cap to wiper motor is pretty tight. Not complaining - its good to have the engine as far back and low as possible.
I had them up for sale a couple of times and should follow up with the guy who bought them as far as fit and performance since they were going into an A-body. I had them coated with zirconium dioxide so curious about that as well. People have been able to fit the TTI shorties into A-bodies, I just couldn't do it on my car without a bunch of mods. Maybe certain combinations don't work out as well. Maybe changes have been made since then - the headpipes certainly have been.
Just a few photos. TTI shorty's on a 68 Valiant 273. Driver side a bit tight but clears everything.Column shift requires their kit(photo)but the stock stuff can be reworked if you good at that stuff.
