Flexplate orientation/Transmission to engine mounting?
Bronze Barracuda
Vancouver
So it's been awhile I suppose, I'm trying to mount the transmission to the block but it seems like the center part of the torque converter is preventing it from mounting properly. I think it's hitting the crank before I can get it to sit tight?
Measure the ID of the crank hole and the OD of the snout on the torque converter
There was a diameter change somewhere over the years
Kinda' hard to fit 10 pounds in a 5 pound bag......
Okay hold up a second here hold up a second. It's all starting to make sense now this engine came out of a truck with a manual transmission so that bushing is for a manual transmission so I'll have to do is remove it correct the brain is starting to work thanks guys!
Yes BUT what I said still holds. I think it was late 60s early 70s but don't quote me
That is only a problem on the 273 engines. The register is smaller on the 273 crank, and the corresponding torque converter about is smaller. And the trans for the 273 has a different spline count on the input shaft than the later 318/340/360
when you tried grease how tight of a fit was your drift in the pilot bushing? if the grease can just push out past the drift it won't work. even with a snug fit you need a really sharp hit with your hammer to pop the bushing out.
I tried several types but I probably gave up to early. It looks as though there's a small step down between the bushing diameter and the crank end diameter. So if I use a drift that will fit into the crank end the grease just pushes past the bushing, and if I use a drift that is snug in the bushing it bottoms out when it hits the crank lip diameter.
fill the bushing right to the 'front' with grease, get your drift that's snug in it and whack it hard with a decent hammer. it'll take a few goes refilling with grease and repeating but it will come out.
neil.
neil.
i find greese and bread works the best for me .
The year was 1967. 1968 was the change over. Like always at this point in time, measure both.
As 66fs mentioned, it was the change made from a '67 273 forged crank to a '68 cast one. The transmission made the same change internally that year....across the board to all 904's and 727's both small block and big block versions. The slant 6 engine also made the same crank register diameter change the same year. All 318, 340, and 360's had the same large crank register. Manual transmission cranks received a final machining for a manual trans pilot bushing, but, most automatic applications didn't get that machine work.
So the OP MIGHT need a sleeve in his crank to makeup the machined difference between manual and automatic crank?
What about using a Tap (of the correct size) to cut into the bushing and then slide hammer it out? (kind of like how to remove the bushing in the Lower control arm)
I really like this idea...
When all else fails maybe drill & tap a couple 5/16-18s for a puller......
then there is this...
No, it looks to be a 360 converter. That will fit all V8' except the forged crank 273. He just needs to remove that pilot bushing.
Seems drilling and tapping two holes in that bushing would be easy. Then just use a puller.
Great idea.
