Optik
can i use the floors from a 63 4-door dart to repair the rust in my 2-door hardtop?
thanks!
-tim
thanks!
-tim
You shouldn't have any problem using the floor pan from a four door on your two door.
When these cars came down the assembly line, the framerails and floorpans were assembled as a unit before it was turned into a two door or four door.
Does this apply to convertibles as well? I know that the `verts have torque boxes welded in at the factory, but is this the only difference?
