nm9stheham
Yes... the cam question dropped to the bottom of my list when the OP showed the smooth operation in his latest video. But valvetrain-related is something like erratically sticking valves.
Since you are working on this, OP. Measure all the resistances of the spark plug wires. They should typically be in the range of 3000 to 6000 ohms and none should be over 10000 ohms. And check spark plugs for tight caps on the upper ends, and firm seating. How new are the plugs?
What spark plug model are you using? And to what distance is the gap set?
Need a pic from the side showing ground strapSpark plugs are NGK BP6ES, looking like this:
And a view looking in the plug
Here read this it should helpSorry, english is not my native language...
What ground strap?
Looking IN the plug, is that possible?
Nice. I am glad you liked the information.Oh, that was interesting!
I had no idea that much could be read from the spark plugs.
I had the valve seals replaced this spring as it was smoking blue at warm up after sitting a couple of days.
Not sure if the new seals solved the problem as it still smokes at warm up, maybe there was old oil left since before the valve seal replacement?
So today I took the little Mopar for a spin on the highway, with a lot of full throttle accelerations up to 5000 RPM, it smoked at first but later there was not a trace of smoke when I pushed the throttle hard.
Removed spark plugs and took some pictures, it´s hard to get the colours right, but the plugs are very clean after this run and the colour is sort of grey-ish, with some changes at the ground strap bend, see pictures and inserted arrows below.
I'm still not sure of what I see, still confused but on a higher level.
View attachment 1715553989 View attachment 1715553990 View attachment 1715553991
Try to find some local amateur radio operators, and if one of them doesn't have a scope, they may lead to other electronics oriented folks
