After talking with persion flywheel company they said the are balanced ther same. The only difference is the magnum has the pickup for crank triger. So if your putting a carb on your magnum any 360 flywheel will work
ABSOLUTELY 100% NOT TRUE.
They ARE different balance. How do I know? Not only do they sell a different MP flywheel, as mentioned, but I measured the holes on my Magnum 'wheel versus my 360 'wheel. The magnum holes are smaller diameter. I spec'd 'em out but that data is in my Magnum engines book in storage. I debated whipping up sets of weights to press fit the 360 wheel holes to balance it to Magnum 'wheels specs.
