Flywheel bolt torque
S Car Go
East New Market MD
Question, I'm about to bolt my resurfaced flywheel to the crank. I bought new grade 8 bolts because the car got disassembled over 30 yrs ago. I could only find one of the originals. How many Ft. pounds of torque do I use? It looks like 7/16 fine thread.
Give us the info, what year and what engine please. I don't know witch book to look threw
LA Engine Torque Specifications Small Block Chrysler 273, 318, 340, 360
* Torque values shown are in ft/lbs unless otherwise noted
* Follow factory torque sequence
Fastener
Torque Thread Size
Camshaft Lockbolt 35 7/16-14
Carburetor to Manifold Nut 7 5/16-24
Clutch Housing Bolt 30 3/8-16
Connecting Rod Nut - Plain 45 3/8-24
Crankshaft Bolt (Vibration Damper) 135 3/4-16
Cylinder Head Bolt 273-318 85 1/2-13
Cylinder Head Bolt 340-360 95 1/2-13
Flywheel Cover Bolt 100 in/lbs 1/4-20
Flywheel Housing to Block Bolt 50
Flywheel to Crankshaft Bolt 55 7/16-20
Fuel Pump to Block 30 3/8-16
Intake Manifold Bolt 35 3/8-16
Main Bearing Cap Bolt 85 1/2-13
Oil Pan Drain Plug 20 1/2-20
Oil Pan Bolt 15 5/16-20
Oil Pump Cover Bolt 95 in/lbs 1/4-20
Oil Pump to Block Bolt 35 3/8-16
Rocker Shaft Bolt 30 3/8-16
Spark Plug 30 14mm
Timing Cover Bolt (cast) 30 3/8-16
Torque Converter to Flexplate Bolt 270 in/lbs 5/16-24
Vibration Damper Pulley Bolt 200 in/lbs 5/16-20
Water Pump to Block Bolt 30 3/8-16<<<<<<<<< 30 FP (HERE)
