Hay yall, we're all Mopar brethren here. Lets have this discussion civilly, ok? Obviously, some people think the FMJ spindles are not a good idea and that's cool. Whatever works for you.
we are way off the original question which only has 2 answers !
Yes i have them on my a-body and have no problem
-or-
i have them on my a-body and have had big problems
Makes no difference?
The article clearly shows that the FMJ spindles are perfectly safe, and possibly have BETTER geometry than the original spindles did. Especially for cars that use larger, more modern tires and tread compounds.
Suspension design and geometry is always a trade off. In the case of the FMJ spindles, you trade a ridiculously slight increase in toe change for a more significant increase in negative camber gain. Simply put, thats a good trade. If you don't understand that, then you simply don't understand how suspension works.
The factory designed the suspension on these cars for use with rock hard, rail skinny, bias ply tires. It set the alignment specifications for those tires. It sized the torsion bars for those tires and their incredible lack of traction. It based its brakes on those tires' lack of traction. So the only question is, do you run bias ply tires?
If the answer is NO, and you still use the factory geometry, then you have in fact significantly altered the handling characteristics of your car beyond the factory specifications.
I don't own an A-body
For the record: IF we're going to squabble over non factory mods on an A body; then it should be 'illegal' to install a 1967 up dual chamber drum brake master cylinder onto a 1966 down model with the same size drums...........
Another modification could be 3 point seatbelts since the B pillars on 1973 down post cars may not be strong enough to support them in a severe crash.
