[WANTED] For 65 valiant
Charrlie_S
Silver Springs, FL
Need the plate that bolts to the firewall, where the steering columm goes through. I need the large plate with four bolt mounting, not the smaller plate that fits around the columm. It is 65 only. The hole in the firewall had to be large, for the cable shift box to fit through. 64 had push button, and 66 had regular linkage, so the cutout in the firewall, wasn't as large. Misplaced mine.
I have one off a '65 Dart but it seems to have (5) mounting holes. Square at top, kinda triangular at bottom and curves at bottom to follow contour of firewall. PM if that sounds like correct part and your interested.
