Hi all,
This is my first ever attempt to do any body work. I am now removing paint. Basically, I used a chemical to remove it and what didn't remove, I am sanding. I am almost done with the outside driver door and am working ont he rocker panel. Surprisingly, there is very little bondo or rust. I am doing a 68 barracuda fastback.
Anyhow, how important is it to remove every inkling of primer? There is a top layer of blue paint, a (I think) white layer of primer or paint, a layer of sliver paint and a red (brick) primer on the bare metal. I have a few little spots of red primer left but it is very thin and flat. Should ALL of it come off? The panel is sanded smooth.
Also, old bondo, should it be removed and replaced with new bondo or just sanded smooth?
So far I am surprised at how I am doing since I have never done this before. Looks pretty good.
Is there a spray on chemical to remove paint? We can't afford a full snadblasting at a shop so we are removing what we can and I was just wondering about the inside of the door under the interior panels. LOTS of little areas so sanding would be very difficult. Should I do all that I can and then have it sandblasted for the rest, attempt to do it myself (have no clue if the store bought machines are very good), or what to get the nooks and crannies?
I know I can learn sandblasting too and have a lot to practice on. Just don't know what the best way is.
Joanne
Joanne
