harvenator
A fish called Wanda
Any one know which Ford rears will bolt into a '65 A body 4 speed to replace a 7 1/4"? I had one years ago in a 64 Barracuda 4 speed but can't remember what it came out of.
The old style Bronco, 68-72?, are the same length, I don't know if it is a bolt right in situation and I think they are getting hard to find...
68-70 Mustang is a perfect fit. Maverick, Comet, Falcon and Granada should work too.
This is great guys, this opens a way for me to save some money because the junk yard up the street wants 1200 bucks for an 8 3/4 a-body rear and only 450 bucks for the 57-59 ford rear... also many more options with the 9 inch...:-D:toothy10::-D
Thanks!!!
This yard has always wanted top dollar for all of their stuff... of course there less than 3 miles from my house, and they have the most a-body mopar parts on this side of Arizona, but still.. I find myself going back because they do have EVERYTHING, its just not affordable. :angry7:
Almost the same length but not a bolt in and has 5 1/2" bolt circle.
The 68-70 Mustang will fit but are wider than the stock 7 1/4 and will cause tire clearance issues on an early A,
The Maverick, Comet and early Falcon are the correct size but only came with the 8" and if memory serves me correctly, the Maverick/Comet rear may need the perches moved out a little.
The Granada is too wide and needs spring perches added.
The only 9" Ford rear end that is a direct bolt in is the 57-59 Ford.
