Sanguine
75 Duster 340, 4 speed, fresh sassy grass green paint w/ stripe decal pkg, blacked out hood w/ scoop, bucket seats,
appraised and reciepts for all parts
serious enquiries only
email: [email protected]
$13,500CAD
all suspension bushing replaced, mostly polygraphite
new ball joints, outer tie rods and sleeves
new rad core
new front brake pads
new rear brakes and drums
aluminum rear end cover/brace
subframe connectors
new carpet
rebuilt hurst shifter
rebuilt A-833 trans
new clutch/pressure plate
new mopar mini starter
mopar headers
flow tech x pipe
flowmaster 40 series mufflers
TTI mandrel bent tailpipes
wheel vintiques rear ralleye wheels 15x8 and trim rings
restored original center caps
14x6 original ralleye wheeels, front
Predator tires, new rear, good front
new quarter panels
new paint and decals
new trunk and front floor pans
rear subframe reconstructed
new fuel tanks and 3/8" sending unit
trunk mat
cd player/amp
autometer water temp/oil press/tach gauges
MSD 6AL ignition
new mopar recurved distributor
mopar alum valve covers
mopar M1 dual plane intake
625 CFM Carter carb
carter fuel pump
all new brake lines/master cylinder
new repro mopar battery and cables
comp cams XE268 cam and lifters
Armstrong machined 340 engine/internally balanced/bored .040"/rods reconditioned, etc.
new valves/gear/guides etc
new front yoke/hi strength u joints and girdles
new windshield and gasket
3.55 8 1/4 cone suregrip diff
less than 100 miles on new engine
and more....
$13,500CAD
new rad core
subframe connectors
new carpet
rebuilt A-833 trans
mopar headers
flow tech x pipe
new quarter panels
trunk mat
cd player/amp
MSD 6AL ignition
625 CFM Carter carb
carter fuel pump
and more....
