i'm pretty sure this is a torque converter for a forged crank, but I wanted you guys to look at it and confirm.
there are no balancing weights anywhere on it. Also there is no drain plug. I thought it would have been on the outside ring of the converter, but there is not one.
I think the drain plug was sealed up....look at the imperfection on the face, I think that is some kinda putty junk filled into the hole. see red circle. that is the only place I can see that maybe had a drain plug in it at one point.
is there a way to put an externally balanced bolt on flexplate on here to save money on a new torque converter?
thanks for the help and input guys.
