What fork , and what ball stud bracket is used when using the 76-80 aluminum overdrive bellhousing in an early a body ???? any help is appreciated :burnout:
Check out Brewers - depends on the vehicle, engine, and bell housing - they make a Z-bar and ball studs and fork specifically for an early 273 mated to a later bell (10 1/2 in)
I used the ball type fork that came in the 81 van that I got the bellhousing out of. Still have the truck trans but used an F-body overdrive in my 70 Dart.
