Formula to shave pistons to reduce compression ??
284* intake cam with bring effective or dynamic compression down to the 9s.
You could chuck ‘em in a lathe and cut a dish in them.
I dunno. Just a thought.
Dynamic in the 9s won't run on pump gas.
The piston shaving idea was for a motor I was thinking about buying. However, due to my having to buy 4 instead of just the one that is broken.They’re discontinued I am going in a different direction. I’m looking at a kit on eBay that is supposed to have Mahle pistons
That will produce 11.7 cr with a 65 cc head. My new plan is to use an .80 thousandths head gasket and take enough off the pistons to get 10.0 cr , very 93 pump gas friendly.
Like a MOAB, that'd be the Mother of All Head Gaskets.
Heck, you'd need longer head bolts or Studs.
