MoparFan
Hi,
I haven't post for a while, did not had time to work on my Dart ... too busy around the house ...
But I finally found a donor for a 360 !! :headbang: I am really happy about that.
It is a Dodge Magnum XE 1978 ... with a body in very bad shape, paid 350$. Will remove drive train, and other good stuff. I should get around 200$ at the scrapyard for it, they pay 140$/ton ... that thing is theoricly not far from 4000lbs. So it will be a cheap 360/727, but the guy told me the trans is bad.
This is when we arrived ... a 25-30 feets drop from the road, on a 100 feets approx. slippery slope... Let the fun begin
Actually went much better then we tought ... a chance we had a 4x4 though. Took about 2h, to remove the from is place, tow it, and load it on the trailer.
Frame is rusted so bad that we jack it to put inflated tire on the back, it bent (I think)...
The car was not started for the last 5 or 6 years. Back home we have put a battery in it, hit the key, and the engine turned !!! Not stick, the starter, the electric windows (slowly but still), the radio, still work ... now we will changed the oil, put prestone, gas and try to fire it. !!!
