I asked him during the video why on the chassis dyno did the mod 360 make less than the stock engine under 3000 rpm but on the engine dyno it made more than stock under 3000 rpms, He only gave a quick guess of maybe torque converter. So who knowGlad you discovered holdener. He has some very good content.
That was you! CoolI asked him during the video why on the chassis dyno did the mod 360 make less than the stock engine under 3000 rpm but on the engine dyno it made more than stock under 3000 rpms, He only gave a quick guess of maybe torque converter. So who know
On another thread we were trying to figure it out, why that happen, I was hoping he would have a little more to say.That was you! Cool
Its a lot of yap yap yap yap on and on and on but the info is pretty good. You just have to sit through the yap yap yap yap yapI would much rather read an article than sit and listen to that guy for an hour.
Even more interesting.. and no having to listen to Richard
Or just watch the original video of the dyno session and results, that's his live show for people to ask questions.Its a lot of yap yap yap yap on and on and on but the info is pretty good. You just have to sit through the yap yap yap yap yap
4 inch crank in 318 block with trick flow 190 heads gave some impressive numbers. 318 blocks are boat anchors ppl give them away not worth building get a 360 and all that nonsense.
well they also shouldn't call a .030 over 360 a 360Not a fan when people say it's 318 after stroking it.
This one had a bad day...
Click bait 318 makes over 500 hp but description fine print says 4 inch crank so yeah misleading. But hey got ppl to click and watch....Not a fan when people say it's 318 after stroking it.
This isn't a freaking 318 vs. the world thread.4 inch crank in 318 block with trick flow 190 heads gave some impressive numbers. 318 blocks are boat anchors ppl give them away not worth building get a 360 and all that nonsense.
No idea why you are being like that...i love 360s... i just posted a video i prefer with a dyno run and not non stop talk.. i like richard but sometimes... Just an opinion after all...This isn't a freaking 318 vs. the world thread.
Just because it's no about a 318 doesn't mean it's anti-318.
It would have power wise for sureInteresting info in video. Some old low compression 360 2 bbl makes 330 torque or something. Then 4 bbl adds like 30 hp no loss in low end tq. At one point headers added 30 torque down low but not much difference at higher rpm.
Pretty easy to swap in decent compression pistons and have a fairly stout 360 mild cam stock heads bowl blended etc. Long throw crank torque.
If mopar would have offered a 360 from the factory with more compression it might have dethroned the 340 legend.
I was being facetious about 318 comment. As seen in that video the 4 inch crank trick flow head 318 block engine made 530 hp which is pretty impressive and some thing anyone with funds could build.This isn't a freaking 318 vs. the world thread.
