I heard him say something about that, never seen the video, aren't edelbocks on par with a decent ported 340/360 head ?Not sure if I was watching the same video, but I saw one where mildly ported stock heads [ bowl clean up & valve job ] were swapped for Edel heads. Zero difference.
Yeah he mentioned that and I don't remember it from before. I thought that was surprisingNot sure if I was watching the same video, but I saw one where mildly ported stock heads [ bowl clean up & valve job ] were swapped for Edel heads. Zero difference.
Yeah I was thinking about that too. The cam was pretty small at that stage. But to gain nothing was surprising. Sure a set of ported J heads can be effective, but man that short side on the exhaust port is just awful. The Eddie's in stock form are definitely better there.It doesn't surprise me at all. If the engine is airflow & rpm limited by the cam, [ engine had a mild cam ] then installing heads that have bigger ports/higher airflow when the current heads already satisfy the airflow requirements of the engine, then the 'big' heads will add nothing...
Could actually hurt performance from big port volume reducing velocity.
Table 1: Intake Port Modification Sequence | ||||||||||
Col. 1* | Col. 2* | Col. 3 | Col. 4 | Col. 5 | Col. 6 | Col. 7 | Col. 8 | Col. 9 | Col. 10* | |
360 Head: | 360 Head: | 360 Head: | 360 Head: | 360 Head: | 360 Head: | 360 Head: | 360 Head: | |||
Stock | Stock | 30- | Throat/ | Blend | Guide | Radius | Gasket | Short side | Fully | |
Lift | 340 "X" | 360 | degree | Bowl | Guide | Boss Roof | Intake | Port | radius | Ported/ |
(in. ) | Head | Head | seats | Blend | Boss Web | Blend | Valve | Match | blend | Polished |
0.000 | 0.0 | 0.0 | 0.0 | 0.0 | 0.0 | 0.0 | 0.0 | 0.0 | 0.0 | 0.0 |
0.025 | 15.0 | 12.9 | 20.1 | 19.4 | 19.6 | 18.5 | 18.2 | 19.0 | 21.0 | 20.6 |
0.050 | 31.5 | 29.8 | 38.1 | 37.9 | 37.5 | 37.4 | 38.4 | 38.0 | 39.3 | 39.8 |
0. 100 | 58.3 | 50.2 | 75.8 | 74.2 | 73.4 | 70.7 | 72.6 | 73.2 | 74.4 | 77.1 |
0.150 | 91.6 | 79.5 | 112.3 | 106.8 | 107.9 | 105.0 | 108.0 | 108.0 | 109.4 | 111.8 |
0. 200 | 124.7 | 112.6 | 140.0 | 132.6 | 134.3 | 133.5 | 134.7 | 137.8 | 136.7 | 137.3 |
0.250 | 152.5 | 142.2 | 162.0 | 157.0 | 158.7 | 158.4 | 159.6 | 164.5 | 161.7 | 162.6 |
0. 300 | 172.0 | 164.8 | 179.8 | 177.4 | 180.1 | 179.2 | 180.1 | 185.3 | 184.2 | 185.5 |
0.350 | 193.6 | 183.5 | 193.2 | 197.8 | 200.0 | 200.1 | 201.3 | 209.5 | 207.0 | 206.6 |
0.400 | 208.3 | 188.2 | 194.4 | 208.7 | 215.1 | 217.6 | 216.4 | 227.6 | 225.0 | 224.8 |
0.450 | 215.4 | 193.8 | 190.0 | 197.9 | 210.7 | 222.8 | 214.3 | 225.2 | 236.5 | 236.4 |
0.500 | 221.0 | 192.6 | 190.9 | 197.0 | 205.4 | 211.0 | 208.4 | 218.9 | 227.8 | 228.0 |
0.550 | 220.7 | 190.3 | 191.4 | 197.0 | 204.9 | 209.0 | 209.3 | 215.9 | 224.0 | 224.0 |
0. 600 | 210.0 | 189.1 | 187.5 | 196.6 | 205.6 | 209.0 | 209.0 | 216.3 | 224.7 | 224.3 |
