I am looking for ideas and suggestions as to where to mount a Fram fuel filter (canister type on my 66 Dart. Stock fuel tank and mechanical pump for now.? I tried searching but couldn't find anything.
If it's the one I'm thinking of it can be a royal pain to use with the stock tank. But it can be done. When using a stock tank the in line ones are better with less hassle and are up out of the way of suspension travel. If you had a fuel cell the cell is located back near the rear of the car and you can mount the filter to the frame rail where it is out of harms way.
