leblanc
member 2883
When intalling frame connectors where do you guys run the emergency brake cable? Over or under the connector?
X2 I should have done this myself.I've drilled and welded a tube in for the cable to pass on a street car.
we have to for the vehicle inspection!you guys keep the emergency break?
I would use it often if driving in the rain when you parkHow often do you take your emergency break?
Thanks for the pic...your underside sure looks goodHere is the picture
Hope this helps
But if I were you I would go with
what Darter6 said.
Thanks leblancThanks for the pic...your underside sure looks good
I seen that also but its OK I SPEELL INKORECALY SUMETIMES TO.I see what you did there! LOL
Maybe they had to put on the brakes to take a break...
Stop it I may be slow but that slow.And the bottom of your car looks pretty nice too!
OK you guys got me (i am a little slow).
I guess I will take an emergency break
when I need a rest.LOL
Darryl
I removed mine back in the day and scotched it :toothy8: Got me too
