Frodee
Off center a bit
Not much to do today everything is covered up while I painted my tranny.
Hopefully they dont have to piece it back together to read it. Pretty funny. Maybe you should put a scatter shield on it.I had a few beers and got stupid while clear coating.View attachment 1715410206 View attachment 1715410208Well what the heck Iv'e had the old Tee handle forever and found a use for it. See what happens when an old man has nothing better to do than be stupid. lol
Yea good idea thought about that. A blanket anyway.Hopefully they dont have to piece it back together to read it. Pretty funny. Maybe you should put a scatter shield on it.
I don't know how much room there is but I was eyongYea good idea thought about that. A blanket anyway.
Sure isn't much talk about them on this site.I am not a fan of blankets, they hold the heat in.
Have a Gear Vendor over drive not sure if I have room for a scatter shield.I am not a fan of blankets, they hold the heat in.
I'm getting close to putting in the engine and tranny and is easy the hard part for me is figuring out the bolt on parts like mounts, flex plate and a few other things that I lack in knowledge.Scatter shield just covers the converter and pan.
Most of my problem is getting the right part. Like now trying to figure out the flex plate to work on a 360 Magnum engine that has been stroked and fit a 904 tranny with a 340 torque converter.I have a 73 Duster, so if you need any pics I can take them.
Most stuff only goes together one way.
Coming along nicely!Most of my problem is getting the right part. Like now trying to figure out the flex plate to work on a 360 Magnum engine that has been stroked and fit a 904 tranny with a 340 torque converter.
You just saved me a ton of looking Thanks.Coming along nicely!
Flexplate need a to be LA 360. Not magnum. Fyi.
Damper is magnum balance.
Been a long time so good to remind me or I'd be taking it apart again. lolWhen bolting on the flex plate, I always match the holes up with the T/C and mark one hole on plate and the lug on the T/C as there is on off set . Easy to line up then and bolt up the first time. But you probably already know that.
Ya looking Good Fred !
Mre the trans blanket holding heat and not having room for a scattershield, you could make a blanket from 'chainmail' you know the stuff 'knights of old' used to wear. it'd wrap the trans well, hold parts in if it had to and being a kind of mesh it'd let heat out. sounds dumb and feel free to ignore me if you like but i have had stranger ideas
neil.
