340 LONG BLOCK ASSEMBLY
BLOCK IS .030 OVER
CLEANED, BORED AND HONED
CASTING DATE 5-26-72
NEW ZOLLNER #Z7071 CAST FLAT TOP 9.0:1 PISTONS
NEW SEALED POWER MOLY RINGS
STOCK STEEL CRANK CUT .020/.020
STANDARD BUSHED 340 RODS
NEW CAM, ROD AND MAIN BEARINGS
NEW EXPANSION PLUGS
NEW SUMMIT RACING .454/.454 LIFT HYD. CAM & KIT #SUM-K50052
NEW MELLING HV OIL PUMP AND PICKUP
OEM CAR TYPE OIL PAN
FACTORY TYPE WINDAGE TRAY
FACTORY STEEL CRANK 340 HARMONIC DAMPER
NEW ROLLER TIMING SET
J HEADS W/340 HP OEM SPRINGS, 1.88/1.6 VALVES
STOCK TYPE ROCKER/PUSHROD SETUP
REMANUFACTURED WATER PUMP
LATE STYLE TIMING COVER
CHROME VALVE COVERS
ASSEMBLED & PAINTED STREET HEMI ORANGE
INTAKE AND CARB NOT INCLUDED
$2,750.00
plus shipping from Edison, NJ 08820
For an additional $150.00 I can install the
Edelbrock Air Gap RPM intake manifold as seen in the pictures
Other options that can be added:
CARTER COMPETITION SERIES 625 CFM REBUILT CARB W/ELECTRIC CHOKE (as seen in the pictures)
OEM ELECTRONIC DISTRIBUTOR W/MP ORANGE CONTROL BOX #P4120505
ACCEL HIGH PERFORMANCE COIL
NEW AUTOLITE SPARK PLUGS
ACCEL 8 MM HI-TEMP SUPPRESSION TYPE PLUG WIRES
CARTER STREET PERFORMANCE MECHANICAL FUEL PUMP
BLOCK IS .030 OVER
NEW EXPANSION PLUGS
CHROME VALVE COVERS
$2,750.00
