Fresh 1972 version 340 engine
physixx
Edison, NJ
340 LONG BLOCK ASSEMBLY
BLOCK IS .030 OVER
CLEANED, BORED AND HONED
CASTING DATE 5-26-72
NEW ZOLLNER #Z7071 CAST FLAT TOP 9.0:1 PISTONS
NEW SEALED POWER MOLY RINGS
STOCK STEEL CRANK CUT .020/.020
STANDARD BUSHED 340 RODS
NEW CAM, ROD AND MAIN BEARINGS
NEW EXPANSION PLUGS
NEW SUMMIT RACING .454/.454 LIFT HYD. CAM & KIT #SUM-K50052
NEW MELLING HV OIL PUMP AND PICKUP
OEM CAR TYPE OIL PAN
FACTORY TYPE WINDAGE TRAY
FACTORY STEEL CRANK 340 HARMONIC DAMPER
NEW ROLLER TIMING SET
“J” HEADS W/340 HP OEM SPRINGS, 1.88/1.6 VALVES
STOCK TYPE ROCKER/PUSHROD SETUP
REMANUFACTURED WATER PUMP
LATE STYLE TIMING COVER
CHROME VALVE COVERS
ASSEMBLED & PAINTED STREET HEMI ORANGE
INTAKE AND CARB NOT INCLUDED
$2,750.00
plus shipping from Edison, NJ 08820
For an additional $150.00 I can install the
Edelbrock Air Gap RPM intake manifold as seen in the pictures
Other options that can be added:
CARTER COMPETITION SERIES 625 CFM REBUILT CARB W/ELECTRIC CHOKE (as seen in the pictures)
OEM ELECTRONIC DISTRIBUTOR W/MP ORANGE CONTROL BOX #P4120505
ACCEL HIGH PERFORMANCE COIL
NEW AUTOLITE SPARK PLUGS
ACCEL 8 MM HI-TEMP SUPPRESSION TYPE PLUG WIRES
CARTER STREET PERFORMANCE MECHANICAL FUEL PUMP
thats a sweet looking engine . are you doing the machine work or do you havereciepts for it . also how much to ship to zip code 94564
Hay, this is at least a bonifide 325 HP folks. From a seller with great feedback too. Caint build one for what he's askin. Great lookin little motor. Here's you a bump to help get it sold.
Thanks for the plug Stroker. I appreciate it.
Poppys67toy - I can certainly get you copies of receipts. That's not a problem. I don't do the machine work. I leave that to the experts. I just design and build the engines. As far as shipping costs out to California, I can only estimate from past experience with shipping engines out west, to be around $350-$400. But that's just a guess. I can get an exact figure if you decide to buy the engine. I will also crate it and take it to the freight terminal for a few extra $$.
Also, a few days ago, I was able to pick up a 750 Holley double pumper that came off of a running car. I can include that as an option instead of the 625 Carter carb for anyone interested.
