Dartn440
Up for sale Fresh motor.
Mild street 360. Jan 1979 date code block. Fresh heads stock 1.88/2.02 valves with fresh 3 angle grind. Surfaces milled for compression ratio of 9.5:1. New Sealed Power .040 H116CP pistons on balanced assembly with fresh bearings, seals, and plugs. New Edelbrock 600cfm carb with electric choke on an Edelbrock Performer 318/360 intake. New COMP cam, lifters, push rods, and springs with 1.5 roller rockers. Cam grind CRSXE274H-10. .488/.491 lift on 274/286 duration. New oil pain, pick up, and Melling HV oil pump. New Edelbrock valve covers and air cleaner. New alternator, distributor, wires, brackets. Built to be Paired with a rebuilt 904 transmission, 2200 stall converter and a B&M external balance flex plate. Ready to drop in to your Mopar street car! $5,500 without trans
Shipping, crate, and freight fees extra. Can have installed in your ride for extra.
