I really didn't want to have to post a status on a problem that started a month ago, but the saga continues. They went to change the oil pressure sensor they said was what was shutting down the motor, or at least causing the CEL, and they noticed...hey, it's a quart low after we did an oil change only 3 weeks ago. Hmmmm. I don't know exactly where that leak is as the wife took it in, I called, no return call. I thought it might be the dipstick tube fitting, it was a recall on my first oil change, but the wife said that wasn't it. In one week the part will be in and I hope this will all be done and I can re install the skid plate I took off.....because as I told the stealership....there's a leak.
