JohnnyB
I have the front 9" drum setup off of my 67. Everything from upper control arms to lower ball joint is there, they could use a full rebuild. FREE to anyone that wants to pick them up.
I also have the 7.25 out of the same car with everything attached (springs, shocks, parking brake cables, etc.). It has new wheel cylinders and a new axle bearing on the drivers side. Needs axle seals and pinion seal. I would like to get $25 because of the new parts (less than 3 months old)
Everything worked properly but was pulled for a front disk swap and 8.75 rear swap.
Located in Escondido, CA 92025 pickup only.
