[SOLD] front A body sway bar
blu340dart
MoBro. Inc.
Michigan
I have a front sway bar as removed years ago from a 74 Dart 4 door car. Im not sure if it is an aftermarket but it looked like it was on the car from day one. It had L shaped brackets mounted to the lower control arms, those have been misplaced. $25 plus shipping from Michigan. If no interest in this then it will be scrapped. Thanks. Greg
looks like f body? I thought they have a slight bend in the middle ,and yes I'm looking for one.
Not Factory it is an aftermarket piece. Especially when you said it has l brackets for the control arms which factory had tabs welded to the side of the control arm.
Also those are not factory k frame mounts on the bar.
But it looks to be a great aftermarket piece for some one without sway bar tabbed lower control arms.]
Good Luck with sale
