Thrasher
YoungestMemberUALocal7
I'm currently rebuilding a 727, just wondering how many springs would be appropriate for a 5 to 1 kickdown lever and a mild shift kit?? When I cracked it open, I can see it has 9 springs stock.
Holy ****! Big thanks for all the info man. Hopefully the added springs and the better kickdown lever will help avoid this problem... if not, maybe a Trans-Go shift kit will be on my next order :cussing:The first and only one I bought caused severe overlap from 1st to 2nd. When the back wheels were jacked up and I held the throttle steady at 30 mph in first gear then manually shifted to 2nd. the wheels all most completely stopped before it went into 2nd. What was happening was the 2nd gear band applied before the low band released. I had to drive my truck for work and it took me 3 weeks to get around to tearing back into it. When I did drop the pan there was a whole bunch of fried clutch material in the pan.
The 5:1 kick down lever will increase you chances of having overlap on the 2-3 shift as the 2nd gear band stays on longer with the 5:1 lever. The whole idea is to get the 2nd gear band off sooner, and delay high gear clutch engaugement slightly. I don't use 5:1 levers, or orifice restrictors.and the better kickdown lever will help avoid this problem...
Thanks, Tracy. Glad to be back on here. I've been pretty busy at the shop for the last 3 years. I hope to chime in more often in the future.
I agree with everything you said about the shift kits, I also like TransGo the best. You're good with the restrictor with the trans-go kit, as that is what they recommend with the kit. With the valve bodies we use, we use a 4.2 or 3.8 lever and install 15 return springs, and use the early style second gear servo with both springs to prevent overlap. By design it's (overlap) a big problem with this transmission and people may not even know it's in two gears at once for a brief moment.
4wd it's an 86' w150. almost have the 318 rebuilt as well
