That's easy to explain. A recirculating ball gearbox always tries to find center with the pump energized. So, if the toe is set so the wheel is off center to the left slightly, the car will have a slight pull to the right, as the box is trying to find center.
This does not usually happen if the wheel is slightly off center to the right, as the road crown fights against it and cancels it out.
This of course is only true as long as caster and camber are close to equal. This is why I always strived to get the wheel perfectly centered with the gearbox in the center of its travel. Just makes for a better job for the customer.
Talk about modern alignment equipment and older cars they are not very compatible as some have to be hung on all four tires and the equipment is to large for closed rear wheel wells. I had to find a shop that could hang their equipment on my Dart.
Last Friday morning I took my 66 Dart in for alignment at 8 am when they opened . I had just changed everything from the lower control arm up ( 73 Disc brake conversion ) .
Would you believe they already had 5 alignments ahead of me .
I talked to the tech and told him I wanted the maximun caster that could be dialed in and to tighten the upper cam nuts at ride height. I mentioned it had an ever so slight pull to the right and that the steering wheel was just a bit to the left of center.
When they finally got it done at 20 to 5 the pull was gone but the steering wheel was now slightly to the right of center. I hope he tightened the nuts at ride height.
