I got a front fender (driver side) with the antenna hole already there. I thought they were passenger side only.
I'm not sure I've seen one on the driver side either....maybe a right hand drive car :scratch:
sure someone didnt add that ? is there an antenna base crown stamped into the metal or is it just a hole drilled into it?
While your talking about fenders,what year fenders are correct for my 65 dart? Is it 64 & 65? looks like a 63 has the turn signal on it and 66 got square by the headlight. Am I right?
Fenders for 65 are 65 only. 63 and 64 are interchangeable, 66 one year only.
What was the difference from 64 to 65?
Ahh that makes since. They are a bit different.The opening around the headlight goes all the way around on a 64, a 65 its partially open for the grille.. The front apron is also different.
