1973dusterkid
Watch This
just have finshed a total front end overhaul how to I set the torsin bars and aline so I can drive take to the alinement shop
X2.....nearest one up this way is over 20 miles, and some of it is windy farm roads the rest is 60 mph thru the fields so I would be trailering it.....The big question is, how far away is the alignment shop?
You're golden then. Trailering is the perfect solution. If you put on tubular suspension parts or parts with more than stock adjustments, Then you need to have a discussion with the alignment tech. He needs to adjust Camber, Caster, Thrust angle, SAI( Steering Axis Inclination) Etc... Not just a toe & Go as we used to call it. You want a Guy that'll take the time to consider your new world parts on an antique car. You should get a full print out of all the before and after adjustments along with specs. This may be stuff you already thought of but I just want to see it go well for you.X2.....nearest one up this way is over 20 miles, and some of it is windy farm roads the rest is 60 mph thru the fields so I would be trailering it.....
5 miles is fine. Set the ride height, get the wheels pointing mostly straight ahead and take it slow on the way to the shop.
