kegr2010 Well-Known Member Joined Jul 10, 2013 Messages 58 Reaction score 7 Location Indiana Oct 30, 2021 #1 If someone does a disc brake conversion on a 73 Dart. Can you use a small bolt pattern rotor. Will it fit the spindle or do you have to use the BBP. Don't want to change rims.
hemi71x FABO Gold Member FABO Gold Member Joined Dec 22, 2009 Messages 7,730 Reaction score 4,994 Location Rancho Cordova, CA Oct 30, 2021 #2 No, you can't. Two totally different brake system designs.
SGBARRACUDA ROY Legendary Member Joined Dec 7, 2006 Messages 22,009 Reaction score 10,664 Location PLANT CITY FL. Oct 30, 2021 #3 You have to use the whole Assembly. Rotors,spindles, small joint UVA’s, KH calipers, etc.
R RedFish Well-Known Member Joined Sep 5, 2007 Messages 25,850 Reaction score 5,348 Oct 31, 2021 #4 Aftermarket like Scarebird would get you disc brakes and small bolt pattern. Just another option.
