front spring hangers
Snake
Mopar Nut
Belleville Canada
I have a nice clean set of front leaf spring hangers coming,is there a left and right,what I am saying are they side specific and if so how do I tell witch is L&R.Thanksssssssssssss.
I just looked at my Dart and they both look the same, the head if the bolt is to the inside and the nut to the outside.
Kenny
They are different on my 63 and 64.
And the 63 is different then the 64. the 64 is beefier.
Got the hangers and only cost 10 bucks for my machine shop to drill the holes bigger for the pivot bolt.Good to go now.
I'm sure you found the pivot hole goes up toward the top. Plus the mounting bolt pattern only allows them to be installed one way.
Not sure what ya mean up to the top,I am not flipping the hanger to lower the stance.Just had to make the hole a little bigger for the new bolt.
