BrendonAF
Member
Good Morning FABO!
I'm out in the garage right now installing a fresh RMS AlterKtion kit on my '67 Barracuda Fastback, but have reached a slight hitch with regards to getting everything tightened down. While the documentation provided from the RMS team was helpful getting everything started, it's missing a few important measurements when it comes to torquing down the following parts:
Eccentric Bolts (for the upper control arms)
Top/Bottom of the shock (where the bolts mount)
Upper/Lower ball joints (on the control arms)
Rack & Pinion (where two large bolts mount to the K-frame)
Any help finding out the above information would be appreciated! I've seen a couple other people show pictures from their RMS install, but nothing that had additional documentation on what everything should be torqued down to.
Thanks,
Brendon
Thanks,
Brendon
