Damn, and I was just planning on running into something!Yikes, dont run into anything...or the fender will cut the tire and it'll fly apart like a split rim. Cut and fold if you can, or patch/trim the wheel well.
Looks to me like you have negative caster, positive caster would pull the wheel back in the wheelwell. You want as much positive caster as you can get. I have mine at +7 with the Hotchkis control arms.
Yeah understand your point but it would be a surprise to me that anyone looking for a handling car would run manual steering. I have the borgeson power steering and a 13" wheel and it finally feels a little bit sporty. The issue you run into with wide tires and low or no positive caster is it wanders a lot. The caster makes it drive nice and straight which is the secret to most modern vehicles.That depends. That much caster without power steering can cause steering effort to be uncomfortably high, because you're actually lifting the weight of the car up in the front when you make a turn.
Yeah, you should be able to get a couple of degrees I would imagine.I have factory upper arms with moog offset bushings. I am going to ask the alignment shop to get as close to performance street driving on the skosh chart. ( Don't have it right on front of me) we'll see how it turns out.
I agree. Have you ever seen a Mercedes in a parking spot with the wheels cut? Looks like the tire's gonna fall off because they have so much positive caster. A lot of them spec at over 10 degrees. You can see the front end lift on turns. lol
what did you use?I have electric power steering, ...
what did you use?
