Riddler
Project EH-Body
I'm helping a friend sell off a bunch of parts he no longer needs. This is a Mallory 4309 Fuel Regulator. Here's the spec's off Summit Racing.
As you can see this regulator is in great shape. It comes with the fittings and gauge, which are not included when buying new.
I'm asking $75.00 plus shipping.
Riddler
Fuel - Gasoline
Pressure Range (psi) - 3-12
Regulator Style - Return
Regulator Location - Inline
Boost/Vacuum Reference Port - Yes
Boost/Vacuum Rise Ratio - 1:1
Gauge Port - No
Mounting Bracket Included - Yes
Fittings Included - No
Rebuildable - Yes
Inlet Quantity - One
Inlet Attachment - Female threads
Inlet Size - 3/8 in. NPT
Outlet Quantity - Three
Outlet Attachment - Female threads
Outlet Size - 3/8 in. NPT
Return Attachment - Female threads
Return Fitting Size - 3/8 in. NPT
Regulator Material - Aluminum
Regulator Finish - Clear anodized
Quantity - Sold individually.
When using high-pressure fuel pumps, a fuel pressure regulator must be installed to prevent carburetor flooding. These Mallory fuel pressure regulators feature housings fully machined from 6061-T6 billet aluminum, and specially designed high-flow fuel passages. These features, combined with a quick-acting diaphragm assembly, make them extremely efficient. A mounting bracket is provided to allow quick and easy mounting.
Riddler
